FactoryTalk View Legacy Conversion Tool Help
CJlikesCHAIRS
May 2015
Nope
65
Hi, I have a new PanelView Plus 1000 that I am using to replace an old Panelview Plus (pre v6, I'm not sure exactly what version). I have a clone on my computer that is 32 bit. We are not changing anything with the system, just replacing the HMI. Most likely flashing the PV+ but I haven't gotten that far yet..
On this clone, I moved the archive file over there and try to restore it so I can run the conversion tool. It then tells me I can't open it and gives me this pop up:
"Unable to restore the application XXX from XXX.
Please check that:
there is sufficient disk space
the application is not open elsewhere
the destination application does not already exist"
I know I have disk space (at least 20gb), I don't have the application open on my computer or the clone, and I just moved it to my clone, so I don't know how it could exist already.
If anyone has run into this problem before can you share some insight? Do I need to find a separate 32 bit computer?
Thanks in advance,
CJ
Thought I got it to work, but no luck. I even uninstalled and reinstalled everything Rockwell to see if it would work. I'm out of ideas with this.
I'm using legacy recipe to download a recipe to the PLC. A little background, the recipes are large. They are broken down into 6 tables, each 16...
124
Good Morning , Since I’m loading a new laptop , what are you doing for the 32 bit FactoryTalk View projects that you run into ? Are you...
3,830
I was reading on knowledgebase and came across this article. Is this article saying that it can restore v5.1 runtime file back to a development...
3,229
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
57
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
63
