FactoryTalk View Legacy Conversion Tool Help
CJlikesCHAIRS
May 2015
Nope
65
Hi, I have a new PanelView Plus 1000 that I am using to replace an old Panelview Plus (pre v6, I'm not sure exactly what version). I have a clone on my computer that is 32 bit. We are not changing anything with the system, just replacing the HMI. Most likely flashing the PV+ but I haven't gotten that far yet..
On this clone, I moved the archive file over there and try to restore it so I can run the conversion tool. It then tells me I can't open it and gives me this pop up:
"Unable to restore the application XXX from XXX.
Please check that:
there is sufficient disk space
the application is not open elsewhere
the destination application does not already exist"
I know I have disk space (at least 20gb), I don't have the application open on my computer or the clone, and I just moved it to my clone, so I don't know how it could exist already.
If anyone has run into this problem before can you share some insight? Do I need to find a separate 32 bit computer?
Thanks in advance,
CJ
Thought I got it to work, but no luck. I even uninstalled and reinstalled everything Rockwell to see if it would work. I'm out of ideas with this.
I'm using legacy recipe to download a recipe to the PLC. A little background, the recipes are large. They are broken down into 6 tables, each 16...
112
Good Morning , Since I’m loading a new laptop , what are you doing for the 32 bit FactoryTalk View projects that you run into ? Are you...
3,822
I was reading on knowledgebase and came across this article. Is this article saying that it can restore v5.1 runtime file back to a development...
3,213
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
116
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
130
