Factorytalk View ME Alarm Lists
tranh2
Jul 2009
Ontario
40
Hello everyone,
I have a question related to the alarm list and filtering of certain alarms.
We've standardized on device control popups and on each popup we have an alarm list banner. For example, we have one device control popup for a single speed motor, one for variable speed motor, 4-20 analog transmitter etc. Through using parameters I can just create one popup for the motor and reuse it for different single speed motors for example. I'm sure you know what i'm talking about so I'm not going to explain more about that.
In each of the popups I have an alarm banner. What I'd like to do is to filter out all alarms except the ones related to that device. So for example if I have 4 single speed motors (motor1, motor2, motor3, motor4) and when I click on the motor symbol the for motor1 I only want the display banner to show alarms related to motor1. Similarly, if I click on the motor symbol for motor2, it brings up the same popup as motor 1, but through parameters info is related to motor2. I just don't know how or if you can filter out alarms this way also.
I have experience in Wonderware it this is easily accomplished through some scripts and alarm groupings. Just wondering if something similar can be done in FTView ME.
Thank you!
There is a filter option in the alarm screens and banners. But to my knowledge you can't modify filter options by parameter file. I believe your options would be to use multiple Banners with individual filters and use the parameter file to control visibility. But, there are screen limitations depending on your license. 15 screen, 30 screen, etc. Now you can use Variables in your Alarm Messages and that might be an option.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
138
Hi all. I´ve got a little problem with my FT View SE alarm window. On my PLC program, I have 200 SINT for alarms, in which every bit is for one...
186
Hello everyone, I am experiencing a strange issue with machine using a PanelView Plus 7 and a CompactLogix 1769 PLC. I am using FTView ME V13...
339
Hi All, I'm currently designing a faceplate for an analog input object, and I'm trying to create an alarm tab with an Alarm and Event Summary...
446
Hello! In FTView SE 13.00 for the AlarmEventSummary1 object I need to add the filter Alarm Name LIKE % %. In the field % % I want to pass a...
549
