Factorytalk view ME - Archive Problem
Jinto
Feb 2010
Peterborough
20
Has anybody had a similar problem to this?
I have worked a fair bit on factory talk view ME but have not had this problem before.
I modified a project in ME version 6.10 using my laptop and made an archive. Somebody else then contacted me to say that they were unable to open the archive because of the “invalid file” error. So I attempted to open the archive on my desktop and got the same error message.
I then tried to open the file on my original laptop and it worked fine.
I made another backup and got the same results, the archive files will only open on my laptop.
Both my desktop and laptop are running the same version of Studio ME installed from the same SI toolkit drive. Both are V6.10.00 (CPR9 SR4) build 09.
Any ideas?
Ok thanks, I had already done that to get around it initially.
I have since contacted Rockwell support and found out that’s it’s a known issue solved by installing the latest patch roll up for FactoryTalk.
I don't have to much experience with FactoryTalk. I am trying to open a .apa file and I am getting a Can not open the archive, please make sure...
2,244
I'm wondering if anyone here is running FactoryTalk View ME version 10 and has tried importing old 32 bit HMI project archive files, say going...
3,589
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
209
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
137
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
183
