Factorytalk View ME built in images dont render
Gomez_
Sep 2014
California
195
I recently updated to version 11, and some of the built in images aren't rendering properly on the page:
I've tried removing it from the project and adding the image file back in, but no dice. Any ideas?
Built in images meaning the project library? Do you get placeholders on the Display but no images drawn? IE: put a motor object, but there's just the corner boxes, no motor, or does it not show anything, including the corner boxes?
That "X" symbol usually indicates a Global Object that has broken its connection to the base object.
But now, I do vaguely recall seeing something like this with images. If I recall, I saved and closed the window then reopened the display and it was displaying properly. I might have had to redo it, but after that it worked fine. It's been a long time though.
OG
By built in I mean the arrows and such that are included by default because they are used in some of the button types. ( move left button, move right button )
Images imported from the symbol library are working fine, images I created and imported are also still working
EDIT
Here is an images of the built in buttons i mean:
138
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
131
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
178
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
200
