FactoryTalk View ME Station on PC - 2 PLC's
camo200sx
May 2019
auckland
Heya
Given lead times on a new PanelView Performance which we'd plan to deploy and connect to 2 x PLC's, we're in a bit of a pickle.
Can we use FactoryTalk View ME on a PC with monitor and achieve the same thing for the time being? Non performance PanelViews can only talk to 1 controller, but will the ME Station running on a PC let us control 2 PLC's?
Cheers
FactoryTalk View ME running on a full Windows desktop environment is not restricted to just one Shortcut to a controller.
I'm not sure if there is a preset limit: there might be a practical performance or capacity limit based on your PC performance.
If you talk to your supplier, they can get you a 30-day free trial license from AB to maybe tide you over until the performance model comes in. That way you could keep the programs on separate PC's. The license for a PC application is limited by screen count. So be sure to get one that will cover your needs. But multiple connections are allowed. I've have used up to 6 with no problem. Also, one more thing to keep in mind that the running man part of the developer software will run for 2 hours. Just make sure you set up your PLC shortcut under the developer tab and not the runtime tab. That will allow the running man test to connect to the PLC.
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
85
Considering the incredible time it would take to get a Panelview Plus 7 , I'm going to get the FactoryTalk View ME Station 30 Display Single...
1,142
What is the main difference between the 2 licenses? I have a lot of experience with the Machine edition but not so much with the Server Edition...
4,130
Hello, I am looking to control 50 identical stations from an Allen Bradley HMI using FactoryTalk View Studio ME 11.00.00. The Stations are...
25
5,960
Title says it all. I've loaded up my program on the emulator, but when I open up FactoryTalk View ME Station, RsLogix goes offline with the...
1,845
