Jan1990
is it possible to switch the language from a string used in parameter file?
For Example:
HMI Tags:
Name: Test\Name -> String with inital Value: Hello
Parameter File:
#1=Test\Name
Is it possible that the text from the parameter will change when i select a other language on the panel?
For Example:
HMI Tags:
Parameter File:
#1=Test\Name
