FactoryTalk View Point speed
gregorytorp
May 2022
new york
Hello,
I have a workstation running a FactoryTalk SE Local Station HMI app. I am running an SE client on the same workstation.
I will use FactoryTalk Viewpoint to provide access to the HMI app
I have two options for network connection to the workstation:
1. ADSL circuit with 2.3 Mbps down and 4.6 Mbps up at 20k dollars
2. Fiber circuit at 95k dollars.
My question is: is the ADSL speed adequate for Viewpoint application? Rockwell techConnect says there isn't a mention of bandwidth requirement. Anyone here with similar setup above?
I don't really have any experience with similar applications. but if you are ready to spend 20-95k I would contact your local Rockwell rep and see if you can get any advice/consulting help before you make your decision.
Hello, I have a workstation running a FactoryTalk SE Local Station HMI app. I am running an SE client on the same workstation. I will use...
1,936
Hello again, We are working on a system that we developed and had been working fine for years. Recently, the customer decided that they needed to...
1,714
I am using FactoryTalk View 8.20. Can I connect to my HMI application with FactoryTalk ViewPoint if I am running a Test Application on a PC? I...
3,795
Dear all, I'd like to access to maximum, minimum, scale and offset values of a point. The goal is only to display those values in a graphic in...
4,216
Hi Guys, A customer of ours has got permission from the consumer to demonstrate a machine he has installed over the internet to other potential...
1,453
