FactoryTalk View SE 9.0 and KEPServerEX OPC
yeimirj
Aug 2014
Valencia
Hi everyone!
I have a problem with FTVSE9.0 and Third Party OPC, i cannot read tags from opc server (KPEServerEX), and i do it without problems in FTVSE8.0.
Example:
* FTVSE8.0 + KEPServerEX 6.4 ---- Works Fine :D
(Can see all tags from OPC on FactoryTalk and OPC Quick Client)
* FTVSE9.0 + KEPServerEX 6.4 ---- Not Work o_O
(Can see all tags in OPC Quick Client but not in FactoryTalk)
NOTE: FactoryTalk View SE v8.0 and FactoryTalk View SE v9.0 in the same PC tested. :confused:
Can you see any OPC tag in FTVSE9? What about OPC simulation tags? What about another OPC server's tag? (you can get free OPC sim sever from a lot of places).
Another OPC server's tag = Not Work, tested with Free OPC Server simulator.
NOTE: DCOM is set to allow Total Control.
Thanks. But how i can do It? :|
Hi everyone!
Example:
somebody know if this KEPServerEX 6 work with FT 10?
There were some pretty significant changes made between 8.0 and 9.0. What is the status of the OPC Server in your FactoryTalk project? Is the name correct? Can you see the tags with the FT OPC tools?
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
126
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
130
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
177
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
200
