FactoryTalk View SE 9 VB writing to string
May 2020
BC
Using FTV 9 SE Local
Windows 10
Trying to use a little VB to write to a string. Keep getting an error.
'Taggroup\Tagname is a string
Dim Note as String
Note = "Enter new Note"
Currently Using ExecuteCommand "set Taggroup\Tagname Note"
Stumped on this for a couple of hours, any help is appreciated. Thanks
Hello, I'm quite new with using FactoryTalk View Studio. I am currently using FactoryTalk View Studio 13.00 and creating a runtime file for an...
970
Is this example really the easiest way to write to an HMI tag in VBA? I've been playing with this for a couple hours and so far this is the only...
16,935
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
154
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
131
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
178
