FactoryTalk View SE and Adobe Reader ActiveX
whussain6
Oct 2013
Newcastle
108
Hi People,
I am new to FTView SE and and want to use AdobeReader ActiveX. I have placed ActiveX on my screen and assigned string tag which has initial value C:/Program Files... as pdf file location.
But still it does not open the required file in FT Client SE when testing.
Any ideas how to configure Adobe ActiveX in FactoryTalk SE?
I never used that activex. Said that, from this webpage:
http://www.adobe.com/support/techdocs/318268.html
The Acrobat Control is designed specifically for use with Internet Explorer; it is not a full-featured ActiveX Control that you can use to enable applications other than Internet Explorer to display PDF files. If you modify the Acrobat Control for ActiveX or use it in applications other than Internet Explorer, Adobe Technical Support is unable to support it.
EDIT:
You can launch an external application using AppStart command from a button.
I always embed the MicrosoftWebBrowser Activex control to display PDFs while still in SE.
After that just call the ".Navigate" method in the VBA to the filepath required.
VBA for Microsoft Web Browser Navigate
Hi mmPLCPrg,
Thanks for your help.
Just another question - I also want to prevent operator to get out of the operator display to desktop. but with webbrowser/pdf you can break the security and access desktop. Any ideas how to stop?
Also how can I disable/remove all those toolbars?
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
154
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
131
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
178
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
201
