Factorytalk View SE and PLC5
jrowe4
Jul 2012
palos park
I’m having some difficulties getting a new FTVSE network distributed application communicating to a PLC5/40b with an ethernet side card.
My controllgix chassis has two enbt modules
1. 192.168.190.10 ( for use with enterprise networks)
2. 192.168.1.10 (for use with internal plc coms)
My FTVSE servers are installed on the .190 network. I have a thin client on the line connecting to the .190 network to display my hmi application. Several tags in my app need to communicate to a PLC5 that is on the .1 network. Application uses hmi tags ( was an old review app). I am trying to navigate through the backplane of my system through the .1 enbt module, but no plcs show up under the card. This is through the factorytalk Linx data path section of SE (for picking the topics that relate to tags).
I tried adding a plc5/40 by right clicking on the ethernet drive for the .1 card and adding my plc5 IP address. It finally displays, but I can’t actually use this as a data path. When I start the app, all my tag links are shaded out as if no connection.
What am I doing wrong? If I open rslinx or factorytalk Linx standalone, I can see the plc5 as well. I am not sure if ftvse is comparable with the plc5, or if I am not following the proper method to acomplish this.
I appreciate any help I can get. Thanks all.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
156
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
132
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
179
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
201
