FactoryTalk View SE - Client VBA to return HMI Server Path
andytimc
Sep 2016
Pittsburgh, PA
I'm working on some VBA code to place all available trend template names in a combo box from the user to select from. That way they can easily modify the data displayed on ther single trend screen.
I use VBA code to return all the Trend Template FileNames that exist in the HMIServer/Trend Folder. This works great when the Client is running on the Server and I use a hard coded path the the location.
I'd really like to find a way to return the Path of the Server project in VBA. That way when I run a client on another machine the VBA will be able to detect the path and then I can point it to the Trend folder so my combo box continuers to function properly.
Does anyone have any experience doing this?
You can use something like this:
strServer = me.application.GetHMIServerComputerName("\AREA")
where AREA is your actual area name. It returns the HMI server name into strServer, which you can then incorporate into a path, something like:
strPath = "\\" & strserver & "\c$\users\public\documents\RSViewSE\HMI Projects\SE\My Project"
or
strPath = "\\" & strserver & "\ftvse\"
The rest of that path is from memory, might not be quite right.
What is the Correct way to move Client files (FactoryTalk View SE)? I have FTVSE Studio installed on a development PC, I created a FTVSE Client...
1,162
Hi, Everyone: I got one project for upgrading desktop PC form window XP to window 10. this PC was running FactoryTalk SE Client application and it...
2,032
Hi Guys, I developed HMI with Resolution of 1920 x 1080 in FactoryTalk View studio SE; and also use same resolution for Client Runtime PC yet...
559
Every since we upgraded FactoryTalk VIew SE to version 13, my Client on my production computer bogs (slows) it down. Everything on the computer...
1,588
Hello sir, Recently one HMI PC failed which FactoryTalk View SE application running. replaced the PC and restored the image and got it up and...
1,299
