FactoryTalk View Studio and Studio5000
mitch11
Mar 2017
Ohio
26
I'm trying to set values for multiple different steps on an HMI display, and then overwrite the PLC tag with the appropriate value when the PLC calls the corresponding step.
For Example:
HMI:
Step 1 - 1000 Value[1]
Step 2 - 2000 Value[2]
Step 3 - 3000 Value[3]
PLC:
When Step 1 is called, write 1000 (Value[1]) to PLC_Tag_A.
When Step 1 is complete and Step 2 is called, overwrite PLC_Tag_A with 2000 (value[2]).....
This process is going to be repeated numerous times, so I don't want to use timers with done bits, and I would like to somehow overwrite the tag with one rung.
Any thoughts?
Thanks!
Just use a MOV instruction. See the attached Snip.
Edit: Cant seem to get snips to post. Here is the PDF of it. If you PM me I can email the Studio 5000 file that I created for this.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
148
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
272
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
758
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
642
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
467
