FactoryTalk View Studio (ME) display crash
Krilun
Aug 2008
Cleveland
44
Good Morning,
I imported a project from an old laptop by importing the .med file. Directly after the import, the displays work fine. If I close out FactoryTalk View Studio and then re-open the project and try to open a display... the program crashes. Following the crash a memory read window pops up:
The instruction at "0x7c27cbed" referenced memory at "0x0000001c". The memory could no be "read". Click OK to terminate the program. (Its a windows error not ME studio error)
Any suggestions?
A suggestion...
After you import the project with a new "app name" check the path below to check your project files. In this folder, there is a sub folder called Gfx that stores all the screens.
C:\Documents and Settings\All Users\Documents\RSView Enterprise\ME\HMI projects\"app name"
If everything looks ok then I guess you should call RA Tech support.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
135
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
262
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
699
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
627
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
461
