FactoryTalk View Studio Multiple IPS
Garedgar
Oct 2020
Texas
Is it possible to make multiple IP setups and change them according to a variable.
Example:
If “Skid ID” == 10
Then PLCPath 192.168.1.3
Else if “Skid ID” == 20
Then PLCPath 192.168.1.4
End
Etc etc…
The reason for this is we have a tethered AB MobileView HMI.
We are making a master MER view file since all these skids are identical from the HMI graphics.
But customer wants the HMI to automatically know when you plug the tethered HMI to skid 10 to automatically go to that set of graphics and connect to that specific PLC, i am able to know what skid im plugging into by using the ActiveX variables for this HMI so that is not a problem. I just need to know if I can script something like the code above into my MER FactoryView Studio.
TIA!
If you use direct reference or database tags you can call the screens using #1 where you pass either the tag folder name or the direct reference topic name. Make your startup screen either detect which machine it's plugged into or put a selector to select which machine. I have used the ActiveX to get the terminals IP address then used the Macro Multiplexer ActiveX to select what #1 would be passed to the screens.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
135
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
262
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
699
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
627
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
461
