factorytalk view studio
jih6896
Feb 2013
Rochester
I am currently running in grace mode and I am using FactoryTalk SE Client to test my HMI. I am able to use buttons to use the Display command to go between pages but when I try to do the same thing using a macro it says "the command 'display' is ignored when issued from the development environment or an hmi server" Again, I am using the client and display works while using buttons. Is the issue that I am still running in grace mode?
Macro
Display WinCC_footer
Display WinCC_Main
Welcome to the Forum !
It's not an activation problem: Grace Period always has full functionality for a week.
The problem is that Macros are stored and executed on the Server, so they can only do Server-side things.
There are a handful of VBA-oriented workarounds for running commands on the Client using mechanisms other than user interface. Knowledgebase document 22007 has an example of using the Event Detector.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
148
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
272
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
758
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
642
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
468
