FAN IN & FAN OUT
ParagUike20
Apr 2008
Mumbai
HI forum,
Can any one Explain me what is the FAN IN & FAN OUT principle in PLC in Functional Block Diagram Language?
If Possible , example would be better to Understand.
Thanx & Regards,
Parag Uike
Hi Parag,
I hope I am putting it right in ControlLogix FBD perspective.
Fan in means signals you are giving in to an FBD block, and fan out is the other way.
for example ActualTemp is the input you give IN to an Alarm block , you get multiple Fan out outputs like HiHi alm, Hi Alm, Lo alm , LoLo alm, ROC etc.
You may have many Fan IN inputs like Lim sw status and depending on these you may SELECT one OUTPUT.
Well.
Well actually I'm a person and not a fan but either way. I'm an old in-my-60's PLC guy and I recently had a project which spec'ed for a...
1,228
Hi, I am trying to have my PLC start a heating fan in a linear manner. A certain percentage at a certain received setpoint. To do this, I use a...
1,607
Hi, I've bought this PLC + HMI from Aliexpress, the one on the right that uses SSRs. and want to connect a 24V/0.2A DC fan to the output. My...
32
7,157
I want a PLC to know when a 120v switch is turned on that powers an exhaust fan. I need to know what kind of relay would work and how i can tie...
926
Do you know a supplier for the following item? Similar parts and other brands are acceptable. cooling fan for servomotor mounting Rexroth...
1,375
