Fanuc Series 90-10 Help needed
The 90-10 was a low-end version of the Series 90 PLC that was only released into the Asian market. I don't know whether any of the 90-30 programming software will connect to it. Try using Logicmaster software and selecting '90-20/Micro' as the PLC type.
If the software won't connect, try the Series 90 handheld programmer.
Can you post a picture or a physical description of the unit?
It was only sold in Asia circa 1993. It was similar to the 90-20 but used a different processor. A few of them ended up in North America on machinery imported from Japan or Singapore. We have replaced a few of these with GE Fanuc Micro PLCs, but one needs to re-write the logic and re-wire the I/O.
If you do not want to replace this, your best bet for parts or programmers is going to be the machine supplier.
Hello,
I have PLC Fanuc 90-10 A230-0376-X002..Can anyone help, which software to use and which cable I can use to connect to the PLC.
kind regards
Hi I have a problem when using the (proficy machine edition) Please help me When I click on "upload form controller" This message appears: "The...
3,049
Hey Everyone, I'm in a bind here at my job we have a GE FANUC Series 90-30 PLC with a embedded CPU in the base plate with 5 I/O Slots our...
33
10,813
I hv a problem on GE Fanuc 90-30 series PLC. The PLC is working fine before this, but having a problem last week after have the power trip to the...
4,601
hi, i having a problem when i try to disable few device net from system, this few device net is io for 1 of 2 zone from system, and now this zone...
1,321
Has anyone worked with on of these PLC's? If so, how do I connect to one? What software do I need? What cable do I need? I'm looking online...
666
