Fatek PLC and Intouch Wonderware MOdbus TCP/IP Communication
-KeNshIn-
Dec 2008
cheras
Hi all,
I'm currently doing a project which is using Fatek PLC and In Touch Wonderware as my SCADA monitoring. I'm facing problem on the communication part which In touch is failed to pull out the data from the PLC. I check the PLC data through ModScan where all the data are successful being pulled out.
In fact I had tried to use a In Touch IO Server named MBENET (modbus ethernet) but it seems like only for MODICON PLC. Or is there any special configuration need to be setup first for the communication under the "Access Name" in In Touch?
Appreciate if anyone can help. Thanks.
Make sure that the communications module is set to Modbus TCP and not FATEK Modbus TCP. Modscan allows for a larger variance in the protocol but the Wonderware driver may not.
did u find the way??
Hi all,
i am facing the same problem..how did you communicate
Pleasee...can any one guide me how to get fatek communicate with Intouch (wonderware)..I do not know which server to use. Fatek uses modbus but...
4,481
Hi everyone, i hope you are doing well i am using fbs 2lc module , i have calibrated the weight by calibrated weight but my value is not...
87
Hi; I have Laptop Lenovo Thinkpad (W10) which don't have built-in Bluetooth. I have a PLC having Bluetooth communication device. I wanted to...
136
Hi everyone I am using Winproladder software for programming FATEK FBs PLCs and in programming, we often use Timers for activation of the...
593
Hi friends, I have a problem. I want to read ASCII data over rs232 standard port. How can I do the reading process? FATEK FBs-CB25 -> port1...
751
