Fatek WinProLadder Simulator
ammar430
Oct 2015
Karachi
Hey,
I am final year student of electronics engineering, and my final year project is on "Solar Tracker and MPPT" I have bought FATEK PLC, 2 STEPPER DRIVES, 2 STEPPER MOTOR, 10 Watt Panel.
I have to move the panel in both directions as its a Dual Axis Solar Tracker.
As my PLC has only digital I/O's no analog I/O's, but still I want to operate my sensors(LDR) through Digital I/O's, which is only possible when i take my LDR output voltage to 16V DC to 24V DC, I will use op-amp IC with LDR to take my voltage to around 24V DC to make it work with Digital I/O's instead of Analog I/O's.
Still i have options to buy a Analog I/O's card to attach with my PLC.
Another problem is that I don't know how to compare 2 values(values of 2 ldr) on WinProLadder(fatek simulator) ?
Kindly help me I have only a month left to complete my final year project.
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
147
Hi everyone I am using Winproladder software for programming FATEK FBs PLCs and in programming, we often use Timers for activation of the...
593
Dears good afternoon! You see I have a small problem, scale the signal of the plc manually using equation of the line and other steps, so I did a...
2,027
Hello everyone, I'm currently programming a Fatek FBs-60MC PLC, converting an old program from an ABB's SLC500. The project reads some analog...
1,678
Good Day! Can anyone help me to retrieve an existing program in a PLC (FATEK-60MA) using WinProLadder? I tried to connect to the PLC using...
3,959
