Fault Reset Via Modbus on Franklin Drive
Bullzi
Jun 2012
Colorado
1,530
Hi everyone,
I am working with 3 Franklin Electric P Series drives. I am communicating with the drives via Modbus 485 with a MVI69E-MBS Prosoft Card.
I want to be able to reset the drive on a fault with a command from the PLC. Attached is the word where I will do that. It is kind of weird (at least to me) how they set up part of the word to be read/write and the rest of the word is read only. Has me second guessing myself. So based on what I am seeing if I just write a 8 Decimal to word 6 and then write a 0 after this should reset the drive. Is that what you see?
Anyone out there deal with Franklin Drives? Any advice would be greatly appreciated!!
Thanks,
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
111
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
510
I've got a G4(board only)with a MMI port problem. I do not know the IP, but I believe that port works. Is there a way to reset the device to...
560
I purchased a used Pro Soft AN-X2-AB Ethernet Module and wanted to know what is the process to reset the module back to factory. I assume it has...
1,464
I am facing an issue module 1756-OF8 is showing the minor fault = recoverable in the module info.How can i reset it?
1,766
