Fault
ypf_108
Jul 2009
china
160
This subroutine L0.0 when set?
L0.0 will be true when the rack fault occurs. OB86 will also get called when the rack fault clears but this time L0.0 will be false.
How to determine is the L0.0 do? thanks
I just started learning S7-300,My project S7-300 DP PROFIBUS 6se71.
That is just the S7-300 rack, not the inverter the 6SE71 of PROFIBUS failure? This fault me how to troubleshoot it?
OB86_EV_CLASS OB86_FLT_ID Meaning
B#16#39 B#16#C1 Expansion rack failure?OB86_MDL_ADDR: Logical base address of the IM?OB86_Z23: Contains one bit for each possible expansion rack: Each expansion rack that caused a call of OB86 is reported as having failed (the respective bits are set). Expansion racks that previously failed are no longer shown.- Bit 0: always 0- Bit 1: 1st expansion rack- :- Bit 21: 21st expansion rack- Bit 22 to 29: always 0- Bit 30: Failure of at least one expansion rack in the
SIMATIC S5 area- Bit 31: always 0
For example, this type do you mean?
L0.0 TRUE means that either a remote Station has been disabled using SFC 12 - OB86_EV_CLASS = 16#33 - or that a rack fault has occurred - OB86_EV_CLASS = 16#39 - and the error type and rack number are held in OB86_FLT_ID.
hello I am getting a 57h fault - Specialty I/O module has not responded to a lock shared memory command within the required limit. Fault randomly...
21
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
91
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
144
Hi, Experts: We have 20 + years old GE PLC series 90-30 stop running (the run led not on and battery led not on) and HMI showing that "PLC has...
198
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
116
