Fed up with Rockwell - Activations ? New Post
Rob S.
Sep 2008
Maryland
739
I started a new thread for this subject. I just tried this...
I went to the Rockwell Automation site / Activation support /Get new activations
Host ID Type - Hard Drive Serial Number
Host ID - f07d60b1
Serial Number ( RS Trainer Software) - 1956012840
Product Key ( RS Trainer Software) - DRX36-YKBNN
When I click next , I am getting this....
No installs are available for this Serial Number and Revision.
I have the software installed.
FYI, Rockwell sent me a e-mail with a a .lic . Below...
# Rockwell Software Activation File
# Copyright (c) 2010 Rockwell Automation Technologies, Inc. All Rights Reserved
INCREMENT RST5KOFE.CBT flexsvr 1.01 permanent uncounted \
VENDOR_STRING=1955011709 HOSTID=DISK_SERIAL_NUM=f07d60b1 \
vendor_info="PRODUCT_NAME:RSTrainer RSL5K (Offline)" \
SN=0000000001 SIGN="00A7 D756 5616 294C 4225 84E8 6E89 4700 \
C076 CD01 3CEA 33EC 02E3 EF2F 2EB4"
INCREMENT RST5KONE.CBT flexsvr 1.01 permanent uncounted \
VENDOR_STRING=1956012840 HOSTID=DISK_SERIAL_NUM=f07d60b1 \
vendor_info="PRODUCT_NAME:RSTrainer RSL5K (Online)" \
SN=0000000001 SIGN="006E 41D5 45FD C967 C44A 5976 97E2 F800 \
E5F2 3723 E3AF D338 EE0E AA2F 12CC"
INCREMENT RST5KPRE.CBT flexsvr 1.01 permanent uncounted \
VENDOR_STRING=2052011418 HOSTID=DISK_SERIAL_NUM=f07d60b1 \
vendor_info="PRODUCT_NAME:RSTrainer RSL5K - Project" \
SN=0000000001 SIGN="0078 C947 7909 C68B 760A F3D4 DBF8 E900 \
DEF7 A7EF B32D C864 1D1C 4C11 4DC9"
I forget what I needed to do with this file. I still don't understand why the present activation I am trying to do with the website will not work. The software is installed.
This seems to be the root of your problem not rockwell.
What did you do with .lic file? it is needed in a directory for your software to reconize it is activated. In the e-mail did they tell you which directory to put it in ? or did they tell you verbally and you did not write it down?
It should go in a location like: C:\Documents and Settings\All Users\Documents\Rockwell Automation\Activations
hope this helps
you can find the path the license file needs to go in by looking at the activation manager.
just make sure and refresh the activations or it wont show up.
I think Tech Support assumed I knew that. It was not the best conversation I ever had with Tech Support. I did get it activated.
Instead of "C:\Documents and Settings\All Users\Documents\Rockwell Automation\Activations"
It was in "C:\Program Files \ Common Files \ Rockwell \ Activations "
Thanks for your help and sorry for being so
impatient.
The path you are using is for an older version of the FactoryTalk Activation Tool. It will work just fine, but newer software will install an updated "FactoryTalk Activation Manager" and the LIC files will go in the new location.
Again, nothing wrong, it will work as is.
OG
Is it just me or is anyone else completely fed up with all this nonsense??? I paid good money recently for RSLogix500, RSLogix5000 and...
176
99,790
I have (or will be getting) a 250A motor that I am building a starter for. The starter will be in 36x36NEMA enclosure with a disconnect. This...
1,645
I have problem with plc siemens that continue alarms "Emergency circuit not fed, how to fix it ? Thanks
2,080
Our three grinding operations HMI platforms use RSViewSE 4.0 distrubuted for both beef and sausage grinding operations as the HMI. There are...
17
8,688
Hi All I Have a power quality meter that I have previously used on A DOL motor as a data logger. I want to do the same on two inverter fed...
1,809
