FFL True/False condition.
KirillIvanov
Jul 2019
Eilat
Hello everyone.
Quick Newbie FFL question.
As far as I understand from YouTube etc. FFL should be energized by True condition from the left. Like:
True |------------------| FFL works
I've put a bit from the left to control the loads but it appears that it works only when this bit is not energized. Please see EN conditions on Screenshots.
Screenshot 1 - Shceme.
Screenshot 2- the only condition I've got FFL to work.
Every time I put a new number at N7:70 it's loaded to FFL no matter if B3:1/1 energized or not. I assumed that B3:1/1 can be removed if it doesn't change anything but it doesn't work with empty condition.
Screenshot 3 0 > 0 which should be False gives a green on EN.
Is this normal or my Emulator doing miracles?
Thank you.
It's 1100 Series B running on RSLogix Emulate 500
VirtualBox_Windows 7_09_09_2019_18_17_47.png VirtualBox_Windows 7_09_09_2019_18_19_22.png VirtualBox_Windows 7_09_09_2019_18_21_24.png
I would only expect to see the EN bit set when the rung in conditions are true. Are you sure that your control word is not used anywhere else?
Where is the logic that controls bit B3:1/1.
Also, what is the purpose of the temporary end instruction?
Still nothing controls it. I'm just doing "Toggle Bit" manually.
At some point I didn't want it to execute the second part if the checked bits are empty.
I'm playing with it few hours and changed the logic many times so perhaps right now it doesn't have any sense.
Well... I removed it and now everything works as expected!
Thank you.
I have a project that is loading pallets into 10 test bays and then unloading them when the test is complete. I am using an array to store which...
174
EDIT: I suppose i should mention, RSLogix 500 V8.40, SLC 5/04 (1747-L542C) Is there is a way to use the FFL instruction in a way that doesn't...
866
So once again i am trying to create a program in unity pro from an Ab program. i have an FFL and FFU in rslogix 500 and need to use something like...
2,229
For those who may recall I had posted previously about the FSC instruction, and while I have a better understanding of how to use it I find myself...
1,386
A couple of questions with RS500 FFL-FFU instruction set. 1-Does the stack load from the bottom or the top, My stack is #N7:50 with a length of...
1,607
