FGEN ever use one how to?
jasil
Jun 2012
Building
48
Since we I've FBD and FGEN block anyone ever use one? My non linear transducer issue is still on the backburner.
I've added the block, given it the input channel data, but now what?
The idea is to take our 7-18ma signal and turn it into something relatively linear on a panel view using the FGEN instruction.
7-18ma in and we need 30"-88" out, but the mechanical motion is non linear hence the FGEN.
You would think :) I suppose I don't see where I add my points. I thought this worked by giving multiple input ma points X and multiple corresponding Y my inchesand the function would attempt to make sense if it for my non linear movement.
That's where I'm stuck.....my cavernous skull needs a screenshot or something lol.
A-B borrowed the FGEN from Honeywell; Honeywell's PAC has an FGEN function block. Double click it and it opens the FB's properties with the data entry table. A-B's gotta do something similar.
Hi All Can Anyone shed some light on how to use Fgen Function . I have to analyse a pressure and detect a leak. . I want to use a linear graph a...
695
Hello, I have googled my question without much luck. I am using the FGEN instruction and trying to find out how to control the number of decimal...
5,583
Hey guys, Here at the wastewater treatment plant I'm working on, I have an effluent reservoir that I have a level sensor for, but need to display...
2,034
Does the RX3i have a function generator to linearize a non linear input? Hopefully it supports about 12 break points...
2,739
I want to linearize 13 points. The output is to be linearized to a temperature range (0-2400 in 200 degree increments) Where do I enter X and Y...
3,455
