File types
Alan Case
Apr 2002
Wagga Wagga
1,268
Hi Phil.
Just wondering why we can't attach jpg files. Bmp files are allowed but they are huge in size and are usually above the upload limit.
Keep up the good work.
Alan Case
: gif jpeg jpg png
used to display in the post itself
Conditions for the file upload
- Max filesize: 300 KB
- Allowed extension(s): .gif, .jpg, .jpeg, .png
- Max width x height: 1024 x 768
- No whitespace in filename
code will be generated once upload completed
use the code to display the image file in the post
Yes, as they said...
bmp is an attachment as it is not displayable in many browsers, plus the file size is enormous as you noted.
Enjoy,
Been trying to work on having multiple data types in a input/output assembly similar to have a powerflex has bools for most then an INT for the...
19
7,853
Working with a new facility and I have never done any Siemens work and trying to find what their old tech left behind. What file extensions...
4,667
All, I have a Mitsubishi F940GOT-C HMI that I need to modify (as well as translate), and I am trying to find the uploaded file type definitions. I...
2,027
Hello, I have to replace an old Fx-2n 48MR. I have a (tested) new unit. In the project folder I*only have* file extension .COW, .DMW, .PMW, .PT...
3,753
Hi, I have a clients machine running Factory Talk View SE release # 8.00 I have set up trending and data logging which has been working correctly...
3,644
