Help with Mitsubishi file types
PLCRookie
Dec 2005
I'm right here...
305
All,
I have a Mitsubishi F940GOT-C HMI that I need to modify (as well as translate), and I am trying to find the uploaded file type definitions. I used the data transfer utility to upload from the HMI, and I got 2 files, one is xxx.F1, and the other is xxx.F1p. I can't seem to find the differences in the file types, and I cannot open either file with the software that I have. I know this is an older unit, and I may more than likely need to convert them to a newer type. At this point, my immediate need it to be able to finish documenting the PLC program, as there was no documentation with this machine, and what is left to document comes from the HMI. Any Mitsubishi experts out there?....
Thanks in advance.
Hi can you help, have a book stitching machine with collates pages in 8 stages. I have installed a camera system that will give an input to...
24
1,903
Is there an output or something that is similar to a screen saver, but you can use in the plc to know when the user is actively using it...
505
I have a Mitsubishi FX2N-64MR-UA1 processor. The 1st analog output card is an FX2N-4DA. It requires 24VDC power. That card is obsolete. The card...
1,583
I have the FX2N-4DA analog output module and I am trying to send a value to one of the channels to give me a 0-10v output. Does anyone have any...
1,398
