Clay B.
think I see why you have a ramp function versus a "trickle" function. You are feeding from a vibrating bed. When this is done a ramp down function is prefered because you can better control the feed rate. Vibration tables tend to be non-linear to the speed of the vibration motor. So be ramping the speed down and monitoring the rate of change on the weight you end up with a more accurate final weight.
If you were using a fill valve the most common method is to have a trickle position. This way your flowing at a slow enough speed that you can stop accuratly.
Also Note: If you take the PLC route. Not all PLC's have load cell inputs. You may still need a controller.
