Finding IP on Panelview plus 1250
Saavedra
Jun 2015
Tijuana
24
Good evening.
I´m trying to find the IP address of a panelview plus 1250, tried resseting it, the problem is it auto-runs when powered down and there is no button to shutdown the application. Is there a way to not make it autorun in order to see it´s IP address, or an alternate way to find it out?
For the time, thanks.
Mario A. Saavedra
Well my IP driver was a bust in your last post lets see if I can give you something more useful for the PV.
2 ways you can try.
Power down the PV and then turn it back on, when it is booting up look for a white dot (or square)to appear in one of the corners of the PV, if it does push it and this should take you to the Config screen.
Some versions did not have this and if you are lucky enough that yours does not then.......
Plug in a keypad to the usb slot on the PV then mash the Shift-CTRL-Alt and Windows keys all 4 at the same time.
This should take you into the config screen.
BCS
Your Welcome,
So now if the PV and PLC are in the same IP range then you should be able to set the static IP on your PC to the same range and NOW use the EthernetIP driver to find the IP address for your PLC.
Good Luck,
BCS
You can also make a autorun.bat file on the root of a USB drive and plug it into the PV. Put this line in the bat file:
ipconfig > "USB Storage\ipconfig.txt"
It will create a text file of all of the IP configurations.
In the ladder logic there appears N7:83. Using Find all... that is the only occurence of N7:83. The only other place that I can see that it...
1,773
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
307
Hey all, pretty new to PLC and got a question regarding finding the MSB or the last non-zero bit in a SINT array in studio5000... I am reading...
847
Having an issue connecting to my Micro820 PLC. I don't have an IP Explorer and I know its MAC Address is 5C:88:16:D8:E6:65. I'm connected to the...
951
I have reached a dead end trying to find an EDS file. Manufacturer says to contact third party tech support. Clueless. RSLINX can see it, just...
1,821
