Finding Motor Driver in Printing
consair90
Nov 2013
HCM City
Hi everyone!
I am searching for the following product, it is used in Printing. Who have seen this product yet? May I have Terminal Connection Diagram or User's Manual?
I am from Vietnam, so My English is not good. I hope everyone will understand it.
Thanks & Best Regards.
The picture of the product is attached below:
That's a `1990's version of a digital DC drive made by Reliance Electric. They are now part of ABB/Baldor.
Due to the age, the cheapest way to proceed would be to replace it with a new DC drive. The motor nameplate gives you the sizing information and the application defines what kind of control sophistication will be needed.
Good luck! (And your English is actually pretty good, too)
Thanks for your advice. My system has 10 DC drives of Reliance Electric. I try to use these drives so that my factory saves money.
By the way, I have the PLC that use in this system. Could you tell me what software does use for it? May I have User's Manual? (I attach its picture below)
Thanks and best regards.
You will find that the DC drives are essentially systems drives. All software is customized to the original equipment and dealing with the programming is impossible unless you are certified and registered as a technician with the original designer's company. That would be the printing press manufacturer in your case.
You have very little other choice but to work thru the manufacturer or their agent with both the Automax PLC and the DC Drives. They are an integrated proprietary system.
That whole panel gives me flashbacks and they aren't good ones. Both the Max Pak drives and the Automax controller were both top of the line products in their day but that day was 20+ years ago. I replaced my last Max Pak about 4 years ago.
I have a plant locally that is still running the AutoMax and about 8 drives. Scary terrible flashbacks
Totally true. Awesome stuff. tis a shame AB-R killed it
Good Afternoon , I have a 5 Hp SEW Eurodrive motor S.O.# 87.8070060501.0002.22.90 KA67/T motor. I'm trying to find the Terminal Block that...
2,079
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
308
Hey all, pretty new to PLC and got a question regarding finding the MSB or the last non-zero bit in a SINT array in studio5000... I am reading...
847
Having an issue connecting to my Micro820 PLC. I don't have an IP Explorer and I know its MAC Address is 5C:88:16:D8:E6:65. I'm connected to the...
951
I have reached a dead end trying to find an EDS file. Manufacturer says to contact third party tech support. Clueless. RSLINX can see it, just...
1,821
