Finding variables in plc program
esl
Apr 2002
surat
Is there any possibility to use "wild character with a string" for search in PLC program? e.g. while searching any program variable , can we get all the variables matching (exactly and similar both) with the variable details searched . (As we do in normal *.XLS - Microsoft Excel Sheet from Find option in Edit Menu )
Are there any PLCs providing this facility?
I am using PLCs from Cegelec, Siemens, GE-fanuc. For more clarification please write.
In most programming programs, if you search for "switch", you will find...
new_switch
old_switch
switch_on
switch_off
etc.
That's as close to a wild card as I know about.
For a search like switch, if the searched results are
switch
new_switch
switch_on
switch_off
etc it's ok.
But is it possible to find out the
switchon
switching
switchsystem
cornerswitch
localswitch
etc too?
Or Do you think both are same ?
You should also be able to find....
switchON
switchOFF
etc.
The underbar is not a delimiter; mearly another character.
A search for "whatever" (without the quotes) should give you any and every occurrance of "whatever" (again, without the quotes) whether it is by itself or embedded in anything else.
Be aware that if you type in a space (space-bar) after the last letter in "switch", such as in "switch " (again without the quotes), the search will not produce any results such as...
switch_is_ON
switch_is_OFF
But it will produce results for...
switch is ON
switch is OFF
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
283
Hey all, pretty new to PLC and got a question regarding finding the MSB or the last non-zero bit in a SINT array in studio5000... I am reading...
833
Having an issue connecting to my Micro820 PLC. I don't have an IP Explorer and I know its MAC Address is 5C:88:16:D8:E6:65. I'm connected to the...
923
I have reached a dead end trying to find an EDS file. Manufacturer says to contact third party tech support. Clueless. RSLINX can see it, just...
1,794
Hello, I have an array of 300 of UDT. In each UDT is an array of 3 DINT and another array of 3 REAL. I have 10 controllers that pull data from...
1,163
