FIR OR IIR filter
naturephoenix
Jan 2015
Vienn
181
Hello guys,
I'm measuring AC voltage and AC current. 50-60Hz.
I have 20 samples per 1ms.
Which filter you do recommended for me: FIR or IIR?
The FIR filter will have very high attenuation of specific frequencies when effectively matched. With this relatively high (20 khz) sample frequency relative to the filter objective (50 - 60 hz), the FIR will have good performance when it is tuned to either 50 or 60 hz. The downside will be data storage and computational cost. This will need to be evaluated based on the platform.
You may get sufficiently good performance from various IIR approaches, with much less burden on the system. There are discussions of first order and other filters elsewhere on this forum. Most are (of course) PLC-focused with slower sampling and performance requirements.
We are Boiler manufacturer. The boiler are used in steel and other process industries. All our boilers are controlled by PLC with SCADA or by DCS...
2,071
Hi, I need some assistance in establishing a modbus RTU connection (communication) with a Micrologix 1400 and a accuvim ii. An AIC was used to...
2,089
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
115
When supplying variable frequency drives (vfd), should we install the line filter (emc) before the reactor (choke), or reactor before filter...
204
Hi. I'd like to have a filter on an Alarm Summary page where I could pick which of the 3 groups I created I want to display on the screen. I...
559
