Flashing TER light on Modicon TSX Micro
peanutsue
Jun 2011
Boise
Again, I'm not a programmer.
I posted yesterday pertaining to my problem.
Is there anything a "lay person", such as myself, might be able to do get my machine running again?
I have a flashing TER light on the Modicon TSX Micro....
The RUN light is a solid green light.
It appears to have a connection between the Modicon TSX & the Modicon CCX17.
The information on the screen of the CCX17 is as it would be if the machine was working properly except for that it's in German and none of the "preset" buttons work.
When I've been able to run - there's a green light on the CCX17 that is on. Now with it not working, I have a yellow/amber light flashing there as well.
Is this a fixable?
Do I need to try to find someone to come work on the machine?
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
112
Hey guys, good morning !! I have a doubt, I'm configuring a 1794-IE12 module using the 1794-TB3G base, using a 1794-ADN with 1756-DNB, the LEDs...
4,101
Dear all i oome to find that my master cpu all leds is flashing and as per manual this means that CPU is faulty so can u advise, is it...
2,359
Hi... I'm still learning how to code for PLC's Using Allen Bradley SLC 500 and RSLogix, I made a flashing bit using timers. Now, I assumed if I...
2,021
We have S7-414H system. We found master CPU all LEDs were flashing. The alarm sequence from diagnostic buffer are as follows: Switchover of...
5,111
