fm 353
fitzpatrick13
Jan 2011
tauranga
Hello, I am at my wits end. I have a s7-300 PLc and a fm 353 controller with siemens stepper motor. I have them all talking to each other. But when I try and just simply jog the motor using the parameterise tool nothing happens. The siemens instruction manual might as well be in Japanese.
Does anyone have a sample program and instructions that will allow me to jog the motor, and then maybe program the motor to move to predetermined positions.
thanks
Unknown equipment for me, but have you seen this short getting started (getting shorted?) manual?
http://cache.automation.siemens.com/dnl_iis/DczMTE3AAAA_6070252_HB/gst53_54En.pdf
Kalle
Edit:
From this manual, page 6:
After the CPU and FM 354 or FM 353 have powered up successfully, the following settings have been
preset by block OB 100:
 “Jog” mode with operating mode parameter BP = 1 (value of velocity level 1)
 Override 100%
 Servo enable set
 Velocity levels: 40 m/min (level 1) and 80 m/min (level 2)
Codesys Ethernet IP Scanner - Won't connect to a Wago 750-353. The Ethernet device and the Ethernet IP Scanner are both running. but then I go...
1,679
I need to reload a program in a siemens/moore 353 controller. We have the special cable, but can't find the CD. It's been years since anyone has...
1,563
We have configured a 353 controller with an ODC block accessible via Modbus. We can access all the readable registers and the data retrieved is...
2,957
I'm struggling to get a stepper motor working. I have it working in inch mode and I can reference the drive and get the sync bit on. When I change...
1,339
Hi thanks for looking, I have a modicon PLC tpcx57353, it has a PC card with part number tsxmrp0256p. Can I use an alternative memory card or...
1,897
