FM 357-2 firmware upgrade
vlad.colesnic
Dec 2006
Bucharest
23
Hello everybody!
I am doing a software upgrade of a line and on two benches of this line I have FM357-2 cards. The software that I am installing here works perfectly on similar lines. The software upgrade that I must do implies a modification also in the FM cards, raising the number of R parameters sent from the PLC to the FM via the FM_Put FC supplied with the card, from 100 to 2000. The problem is that while doing the parameters update the FM card sometimes blocks. If I Restart the FM card from the Parametrize software for FM357 cards, the transfer continues from where it was blocked.
The only reason that comes in my mind is that as this line is older, also the firmware of the FM cards is older. Now i want to upgrade the firmware to the 5.03.03 version to be the same with the other lines. Only that I have never done that action before.
I accesed this link: http://support.automation.siemens.c...tandard&viewreg=WW&objid=28422478&treeLang=it and I downloaded the firmware for the (LX) license type and the tool FM357 upd. The problem is that when I launch the FM357-2 Upd and choose the firmware downloaded from the site, the No EPROM driver installed message appears. I have never done such a firmware upgrade before so I do not know what should I do.
1. Do you think there could be any other reason instead of the firmware for which my FM card blocks while receiving the R parameters?
2. Do you know how a firmware upgrade to an FM card can be done? Do I have to connect to the FM card normaly through the PLC or is it anyother way of doing it?
3. Do you have any detouring solution (as restarting the FM automaticaly from the PLC when the anomaly occurs - if possible)?
Thank you in advance,
Vlad Colesnic
Hello, I’m still a novice when it comes to plcs, and I’m currently facing a problem I need help on. I’m on site at the moment, and connected to...
1,531
I am having trouble with a FM357-2 4 axis control. The icon in Step7 5.5 SP4 shows the red triangle STOP icon but it doesn't have an operating...
1,583
I'm having an issue connecting to a SCADAPack 357 over Ethernet for programming. I can connect by Modbus/USB fine. It has an Ethernet address...
2,843
Greetings to All, In our project, we have SCADAPack 357 and it to be interface with GPS via Serial Communication RS 232. So I need to know how to...
1,553
we are working SCADAPack 357 for some project. we have also completed project on SCADAPack 314,334.We can not go online to SCADAPack 357 by com2...
2,162
