FM350-1 5V encoder question
jac
Aug 2009
Ontario
126
Is there a problem with using a 5V encoder signal paralleled from a drive? I would assume just connect the A’s and B’s without the need for the 5V supply. Well the card still give the 5.2V supply error.
Thanks for any input…
You can hit problems unless both of the devices that you feeding have the same DC common. Does the second device have an isolated input, and remember, you won't just need the A and B signal but also the 0V. Next you need to know that the drives 5V supply can cope with the extra load of another pair of inputs. It is one of those things that might work perfectly or might come back to bite you on the bum. Personally I would look at using a splitter, but hey, I like to sleep nights.
Bryan
I am trying to replace an old Relience system with S7-300. The system has an encoder that uses external 220V supply and has 12V A,A*,B,B*. As...
1,151
Hi All, First time I have ever worked with encoders and I am having a slight issue. The encoder is set up counts up and down and works well for...
2,040
I have a S7400 414-2 DP fw5.3 with a CP443 6GK443-1EX30 fw3.0 and FM350-2 on profinet The interface module is a 6ES7153-4BA00 fw 4.0 (ET200M...
1,917
I am using FM350-1 with S7 315-2DP. I use the counter module to count the encoder pulses and cut a crossing plate on the desired position. I do...
1,744
For a revamp we will have a configuration with S7 1500 and FM350 in ET200M on profinet. Will the FM350 work? Because I see in Siemens Tia...
2,754
