For Next Help
set-csg
Nov 2006
ILIGAN CITY
42
Hi Everybody,
Can you give a specific example on how FOR NEXT INSTRUCTION is use or applied in an industrial setting. I know how these particular instruction operates but I cannot relate it on how this one is applied on actual plant or factory operation.
Pls. help me, if you have a specific program as far as FOR NEXT in S7 200 is concern, that would be find if you can share that to me.
set-csg
Set,
Suppose you had a plant that had 10 storage tanks, each with a level sensor with an analog output. Your HMI screen has room for only one level display at a time. Using a For-Next Loop, you can create a routine that reads the value of each tank and displays it for 5 seconds, then moves to the next tank, until all 10 have been displayed. Then the For-Next loop repeats.
For I = 1 to 10,
Display Tank (I)
If Timer (1) >= 5 sec, then Next I
I will leave it up to the students to fill in the details!
For Next Help Hi Everybody, Can you give a specific example on how FOR NEXT INSTRUCTION is use or applied in an...
1,962
I've got this start screen where the user has to enter their username and password. The username and password feature works fine. However, I want...
1,476
Anyone know what the little green triangle on SCREEN 3 means ? See picture Thanks
473
What do you guys think of this representation for on/off contacts? C003 is on, then others are off. I have never seen the logic represented in...
1,809
Is it possible to get a report about used digital inputs on GE Proficy? I want to set what inputs are available.
1,109
