Force Cooling in Motors
ssana168
Jun 2011
Pakistan
38
Dear all,
I need to run 2.2 KW induction motor at 10 Hz frequency or 290 rpm speed. The base speed is 1450 rpm or 50 Hz frequency. I am using OMRON V1000 variable frequency drive for this motor.
I have enabled Electronic thermal overload by setting its parameter L01 = 2 (Blower Cooling) and attach 8 inch fan in place of motor fan cover to cool motor forcefully.
At 10 Hz, motor is taking 4 ampere, so i realized that it is necessary to forcefully cool the motor by installing small panel fan in place of motor fan cover.
It is currently running fine.
Is there any way to reduce the current, so that i can run motor without force cooling????
VFD is currently providing 90 Volts at 10 Hz speed.
Anyone has good idea to run this motor in a better way than please share. I will be very thankful
Dear all, I need to run 2.2 KW induction motor at 10 Hz frequency or 290 rpm speed. The base speed is 1450 rpm or 50 Hz frequency. I am using...
17
4,633
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
269
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
113
Hello all, I have a question in regards to RSlogix 5000. I am having issues with the program force closing when I try to make online edits. We...
128
Hello all, I have some parameter files that I'm using. Most of the tags are direct reference to the PLC, but a couple are HMI tags. If I change...
492
