format tag list simatic.net OPC
boneless
Feb 2008
OKC
1,628
short question.
I have a costumer that has installed a simatic.net OPC server. I am making a tag list for him to import. I thought it would be nice to make it a format that he can just import into his system. Does anyone have an example document that I could look at?
Hi all, if I remember correctly, there is some way in a ControlLogix (or CompactLogix) where you can sort of map tags into SLC addressing format...
1,162
Good day, I'm finishing a program that someone else has started. The previous programmer used the following tag format in several locations...
1,616
Hi, I want ot take data from a RSlogix 500(Table structure) using the DDE/OPC topic definition and want to display data in Wonderware using...
6,773
In a PV 5310, can you format a numeric object to create comma's in the thousands position? I see no way from the properties panel.
458
I can't see any option to display the date in UK format, i.e. dd/mm/yyyy Is it available in TIA Portal v18?
21
1,799
