formulas for calculating transformer
ford
Mar 2003
26
I am looking for the formulas to caculate transformer kva the fuse rating for single phase and 3phase input and single phase output
example if I had a 3ph.input of 220volts and an output of 110v 1ph
15 amp what would be the kva,how many amps would it draw at 220v 3ph, and how should i caculate the fuse protection .
thanks !
Off topic here, but I know many of us use excel quite a bit, so I thought I'd give it a try: I've been playing with MS Excel for awhile now...
2,737
Can anyone help me out with the "TRUE RIGHT" formula of finding how much a cylindrical tank will hold in h20 that can be converted over to lbs? i...
19
4,669
In the thead about the volume of a cone I showed a formula Pos(t) = a + b*t + c*pow(t,2) + d*pow(t,3)+e*pow(t,4) + f*pow(t,5) that I said was...
2,544
Hi all... I have a machine that processes rolls of rubber coated fabric product through a slitter and rewinds the slit stock. The current PLC...
8,960
Guys I need a little help. Nothing major, If I put 17 VAC 3 phase into a 3 phase bridge rectifier what is the DC voltage that I will get out...
2,209
