From RSView 32 to RSView ME?????????
Eugenio
Mar 2007
Juncos
25
well i just know how to program in RS Logix but I need to pass an RS View 32 project to RS view Machine Edition, i was reading the user manual but it does not work at all for me
i need to copy all the tags that the RSView 32 has in RSView ME? because the PLC (SLC 500 5/04) was working with the project in RSView 32
the PLC will be conected to a Panel View Plus 600,
please any help
Eugenio,
I thonk the lack of response to your post is that there is no question in it. I'm not sure what you are asking. My suggestion would be to give more detail and ask a specific question.
Marc
You can export the tag database from RSV 32 and import it into ME with some small changes, RSV 32 has a couple of extra columns of data that need to be removed to make it work. Export both databases and look at the difference and you will see what needs to be done to match up.
The macros can probably be copied into the ME project provided they don't use any functionality not supported in ME.
The graphics are not compatible so all screens will have to be built again.
Hope that helps.
Hope that helps.
i try to import the tags to ME and dont found how, I founded how to import but for SE Stand Alone
The grapics are all ready
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
300
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
258
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
811
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
797
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,407
