FTV ME Screens for Multiple Identical Machines on one PLC
Geoff White
Oct 2005
Brisbane
461
I am building a system that has three identical machines running in a single Logix PLC as separate programs: Cell1, Cell2, Cell3
There are going to be three screens that are used to run the machines.
The obvious way to do it is to build a screen for Cell1 and then clone it and replace instances of cell1 with cellx. However this is somewhat time consuming after each update.
I know you can pass the program name as a parameter when a screen is opened so I can add a parameter file for each screen specifying the cell number to use in the tags.
Is there a way to specify a global parameter that can be substituted to every screen so I only have to alter one parameter to change a screen from one cell to another after cloning?
How many tags do you have on each screen?
Depending on how you do your tagging, CTRL-R does a tag substitution on what you have selected.
From the Manual...
(Rockwell Automation Publication VIEWME-UM004Q-EN-E - March 2022)
Use these global connections to replace tag placeholders in displays that use
parameters when they open:
• Parameter file — identifies the parameter file for the display being
opened remotely.
• Use Parameter List — notifies the application that a parameter list is
to be used to provide the parameters to the display being opened
remotely.
• Parameter Tag #1-10 — the tag values assigned to these global
connections will replace the tag placeholders on the display being
opened remotely
Chapter 25, pages 401-415
Hi Guys I have seen on you tube an AB video showing FTV SE sending different HMI Pages to different monitors. We are considering installing some...
3,980
Is it possible to copy individual screens from one project to another in Factory Talk View Machine Edition. I have FTV ME 8.1 and would like to...
3,823
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
135
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
107
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
147
