FTV ME Station issues
JonAW
Sep 2013
Somewhere
121
Hi All,
I am experiencing some issues with a Factorytalk View ME Station. It is FTV ME Station 8.1 (8.0 *.MER file) installed on a desktop i5 PC running Windows 10 Pro communicating to a ML1400. I have set the system so the operators must initiate the running of the application as the comms to the PLC would not make if the application opened automatically in the Windows startup.
Almost every other time the PC is restarted (which happens a couple of times daily as there is no mains supply on site - they are running a Derv generator) FTV is 'Unable to load application'. Usually a couple of PC restarts gets around the problem. I have installed the ResDir app to see if that would help but it hasn't.
The system is due to be handed over and my system is the only thing preventing this. Does anyone have any ideas on how to get around this issue permanently?
Thanks in advance
Jonny
Ok, Thanks for that, I'll look at that again. I have several iterations of both the ME & SE versions 8 & 8.1 running on windows 10 without issue. I may have jsut been lucky with those!
It may or may not help, but I had an issue with Siemens WinCC, where from time to time the WinCC application started up before the SQL server did. So I used Windows TaskScheduler to delay the start of the WinCC application by x amount of time for the booting of the system to "settle down" and the SQL service started. Again, not sure if it would help you or not, but it's an idea.
I have an existing FTV SE application running on a computer and trying to add another "station" at the location. The application is FTV SE v12...
857
Hi guys. Sorry for the dumb question but I am still new. I have learned to pass Parameters using an HMI tag so far. Can I write directly to the...
925
Hello all, I've got an a 11 year old Touch screen/panel PC running Windows XP with FTV ME Station V4. I had planned to replace this PC for...
2,270
I get so confused by Rockwell's licensing structure. I have two PC's that will be running the same SE application. Can/should I run this as...
1,841
Hello! I created a project in FTV Studio for a PanelView. When I try to launch the application with ME station, I have a pop-up saying that the...
5,706
