FTV SE 5.1 Users and Restrictions on graphics
Adam83
Jun 2007
Perth
Hi all,
Have a quick question for you. I doing a FTV SE 5.10 project and need to know of a way to restrict access to objects on graphics if the right user isnt logged in. Similar to what Citect does with the "Access" tab on its objects/symbols/buttons.
For example. I have a button on the graphics, which navigates to another page (argument on pressing the button is "Display MaintPage"). And i want to be able to only navigate to that page when you are logged in as Maintenance or Engineer user (users are created already). So in effect grey out the button, or emboss it etc when not logged in as the correct user.
Can someone give me an idea of how to accomplish this? I have looked through the different Button objects available, to see if one has a "required privilage" field you need to enter but have had no success.
Regards,
Adam
No idea about SE, but in ME for PV+, I achieved a similar function by only making the button visible when the current user access had the required priveledge.
With this Factory Bauk (credits to PLCs.net forum), who knows what will/will not work... based on what has been posted here that is....
I gave up entirely on trying to use FTViews "Security", as it is broken, frustrating, and corruptible by walking past the server computer and looking at it funny.
The best way, is to maintain a list of privilege levels in the PLC, and toggle bits there to enable different access to buttons/pages.
Just have a numeric entry field, that you can enter in a number. In the PLC, check that the 'Access' code matches something, and set a bit for it. Use the bit in the visibility tab on a control. It's up to you if you also want to run a timer to auto-timeout access.
I'll give you example with 2 usergroups - Default and Logged. Default has key A only Logged have keys A and B
on animation tab add Visibility animation and as expression add the follow line
If CurrentUserHasCode(B) Then 1
else 0
If current user is logged he will see this animated object otherwise this object will be invisible
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
139
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
110
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
150
Hi to all, Does TIA portal support creating reusable pop-up display as FTV has it implemented? Something like on link below. Thanks in advance.
545
Hi all, I have a question about the communication from the FTV and the PLC for different machine I use. Most of these use a SLC5/04 PLC and...
310
