FTV V9.0 and KEPServer for TCP Modbus
EICS
Dec 2008
Melbourne, Australia
323
does anyone have good experience with the sorcery of using a Panelview with Firmware at V9.0 and KEPserver V5.19 ?
i do have the right compatibility as i checked the compatibility technote for the versions required.
i can see my tags online when i browse and can establist the connection, but in "Test" and Runtime at the terminal the data is not valid or communicating.
i know my Kepserver is ok as i can see the valid data by quick client and a modbus 3rd party app (CAS Modbus), its the clunky rockwell side that is not working.
to make matters worse it was a working application, i just had to update the firmware version of the terminal so i could add another shortcut for new 1756-L83 cpu.
now i have this CRAPServer issue!
This issue is now sorted. there is a known bug with V9.0 and KEPserver
its a quick fix within the KEPServer runtime config, just need to "Uncheck" some option boxs. create a new runtime and download to terminal, the "Test Screen" also works after the correction.
from Rockwell tech support below.
Thank you for contacting Rockwell Automation Technical Support!
There is a known issue for FTView ME v9.0 working with KepServer while the ME application default language is NOT ‘en-US’, e.g. ‘en-AU’. Please refer to the RA KB 1043684 - FactoryTalk View: Application using Kepware (Ex or Enterprise) shows wireframes for the solution.
does anyone have good experience with FTV Panelview Firmware version V8.1 & V9.0 and Kepserver modbus tcp comms to 3rd party? i have an PV1500+...
2,965
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
134
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
104
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
139
Hi to all, Does TIA portal support creating reusable pop-up display as FTV has it implemented? Something like on link below. Thanks in advance.
535
