FTView 8, HMI Tags parameters
Adam Bullen
May 2012
Taupo
Is it possible to access the parameters of the local HMI Tags parameters?
I have looked everywhere and this simple thing frustrating me to no end.
In Wonderware I simply have tagName.MaxEU or something similar and the value pops out.
What is the equivalent in RSView? I can't just pull in the value from a PLC.
Something in FTView equivalent to WonderWare?
You aren't going to find that.
WonderWare is polished, slick fast, smooth, refined, subtle, and doesn't try to take complete ownership of the PC it is installed on.
FTView is a turd.
You cannot actually use any tag fields, except to display them, using a special "Advanced" object called a "Tag Label". That is it.
You can get to them in VBA, but that is only because Rockwell needs to allow VBA to have the functionality that they intentionally left out of FTView.
Put them in the PLC, read them as string's. That is what I do.
I even keep min/max setpoints in the PLC.
FTView is total garbage, and Rockwell just want's to keep it that way.
I am looking for some suggestions on the best course of action for migrating my customers FTView SE Distributed project from v9 to v12. The...
1,881
Okay hopefully I can explain this correctly. I created two HMI tags to monitor production on a machine. One is a device type and the other is...
4,333
I have a customer with an SE distributed application. It's version 7 running on a Windows 7 32 bit server and three VersaView Clients running XP...
4,289
I have running FactoryTalk View SE v7.0 on Windows XP normally for a long time Now I have the following error message : Database conversion or...
2,118
