fuses in series to increase rated voltage?
Kataeb
Jan 2007
www.livelovelebanon.com
636
can we install 2 or 3 fuses in series to increase rated voltage?
it is for a solar project requiring 800 vdc.
the normally used solar fuses rated 1000 vdc are too expensive, and the project is way above budget.
so we are considering using low cost 400 vac gG fuses, to be put in series, till reaching the required rated voltage.
NO.
Absolutely not.
If one clears, it now has the full over-rated voltage across it, which could cause serious mechanical failure (read: Explosion).
The very last place to cut costs is on safety. If one of my vendors even considered cutting corners on safety systems, they would be immediately blacklisted.
NO.
Absolutely not.
I was puzzled as to how the OP thought this would work, surely a 400V fuse is a 400V fuse whatever you do with it ?
it is mentioned " Maximum Operating Voltage UL/CSA: Main Circuit 600 V " , so if one pole contact fails...
You are not comparing like for like, you can't apply contactor ratings to fusing. A fuse is a protective device, a contactor is a switching device. Just fuse it correctly.
The added voltage rating from putting contacts in series only applies to switching DC, because it increases the total dielectric in the circuit and quenches the arc before if burns the contact material. That has no bearing on how a fuse works.
I had to do a double-take on the original question.
No, emphatically NO.
These are fuses, not resistors, nor contactors.
They have a rated voltage and current-carrying capacity.
They are not to be under-specified unless you want a fire/explosion/loss of life.
Please spend the project money on the correct fuses.
Go ahead and give it a try, might or might not work!!
As YOU will be the first and last person to do this please post pictures of results! ASSuming you are still alive.🍻
Lol
this is perfectly acceptable two 400v fuses taped end to end then cut the last one in half for 200 volts and tape it to either end of the last two you put together and it should work fine. oh by the way be sure and use electrical tape instead of duct tape don't cut cost there because duct tape is only rated to 375.256 volts.
Mate, You should not make jokes on this subject when OP is so clearly out in the wild with regards to electrical engineering..
For OP. Correct fusing is never too expensive. If your(/your companys) project is over budget, its becouse budget was done by totally incompetent people and they should carry the responsibility and that means they should really not think about cutting safety short.
I'm not sure we should be joking about this subject. There are some very green students who visit this site.
Edit: TurpoUrpo types faster then I do.
I'm trying to include MOVs and fuses for solenoid PLC outputs in a panel with limited space. Does anyone know of terminal blocks that have built...
246
Just wondering what other folks have used on their digital output loads when using this digital output module. There will be a number of...
1,083
In the termination "server module" there are holders for three glass fuses. Is this just for convenience or are the fuses needed? If so, what are...
882
In my car I have 2 cigarette lighter outlets. Dashboard outlet has a 25A fuse in the engine compartment. Cargo area outlet has a 30A fuse next to...
22
4,803
Im teaching a course in Motor control in about a month. I have a couple of questions about fuses if anyone can help me. Im trying to show the...
32
5,862
