FX1N timer
walters
Feb 2005
reusel
185
people help me out here
im writing a program on a FX1N PLC and in this program im trying to use T246
in the manual stands it is a 1msec timer but when i program it, it looks like a omsec timer cause it wont start running. so i thought maybe because it msec monitor is too slow and i connected an output to it to see if the output gets high but no result
do you guys have ever had the same problem?
regards walters
Walters,
Not sure I understand the question or the problem, so the following may be way off the mark.
What K value have you used? You could try K3000 which should give you a 3 second on-delay timer.
I hope this is of some help.
Regards,
Nigel
the valeu i used is k5000 but no result i tried all the 1msec timers the FX1N has but not even 1 of them is running when the conditions are threu.
this is what i made to test the timer but it wont run what is wrong??
Wrong is in m1
Iknow what is wrong. M1 is always ON and make reset on timer.
This is solution for you!!!!
|M8000|----------------------(M1)
|M1|-----------------------(T246) k5000
|Y000|-----------------[RST T246]
|T246|---------------------(Y000)
Hi guys, Im trying to set the real time clock in my Mitsubishi FX1N, but it shows this error ES: 01800001 I have good communication with...
166
Hello, I'm trying to delve a little into rs-485 communications for a couple projects of mine. Until now I've been using a delta vfd and a delta...
125
Hi We're having issues with an FX1N-1DA-BD Analog output module. We're using an metallic contamination sensor MCS 1000 to detect particles. This...
109
Hello people, i'm new with the mitsubishi FX1n-24MT plc and with the gx developer its very new to me and i want to implement for students a stand...
924
Dear Expert, I am doing troubleshooting positioning control in Servo amplifier Mitsubishi MR-J3-A. He get pulse train input from FX1N. PLC...
1,669
