Fx3u program
isajadh
Apr 2006
Dubai
IAM using an fx3u unit. I have 6 (OR) rungs in a program which will turn on an auxiliary relay . How can I simply the steps
Put the six rungs into one rung - with all the contacts in parallel?
-----|---[ ]----|----O--
Poet.
(That didn't work too good . . .)
Thanks for your reply. Yes your drawing is right
But is there any way to combine them all like zrst resets up to 8 inputs at a time . Is there any ways to make inputs like that?
Hmmmm. . .
[ ]---------------O--|
In-1 |
In-2 |
In-3 |
etc. etc.
(Apparently it does not like 'white' spaces . . .)
use Kx anotation
K2M100 will take 8 bits (from M100 to M107)
than https://imgur.com/a/N4NRqQb
N4NRqQb
with ladder logic, if the 8 M contacts are consecutive beginning with M100
|--[ <> K2M100 K0]---------O---|
I'm a beginner in the automation field and I've set up an automation system connecting several devices (datalogger, radio, etc.) via Modbus RS485...
220
Hi All, want to ask. I have PLC a programme to control the valve. The existing programme is to control valve A (Y22), and I want to change to...
148
I have created the following program in gxworks2. I don't understand why it won't read in the analog value. Sometimes it displays the value but...
1,859
Hello I am new on mitsubishi cpu plc programming. I need help regarding the programmation of an actuator. In fact, the actuator move between...
2,026
Hi all I have no experience with Mitsubishi plc's and have a machine with a FX3U-16m. I have been given a program for it from the manufacture...
1,775
